Re: Farmall 400 toplink.. want to make it hydraulic.
Posted by wallacedw on June 23, 2008 at 13:21:27 from (24.225.17.43):
In Reply to: Farmall 400 toplink.. want to make it hydraulic. posted by wallacedw on June 23, 2008 at 12:04:48:
Here are the pictures of the current set-up. If the toplink was fixed in one spot it might work but as is it won't.
third party image third party image third party image third party image third party image third party image
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
