Re: Farmall H 12 volt conversion
Posted by Janicholson on June 24, 2008 at 07:46:01 from (64.83.197.176):
In Reply to: Farmall H 12 volt conversion posted by Shahn on June 24, 2008 at 06:49:53:
Bob abd NDS are correct, leave the Ignition system as is. You will find no wires going from the panel button. leave it this way when changing the amp meter polarity, and other wiring. JimN
