Re: Farmall H 12 volt conversion
Posted by old on June 24, 2008 at 08:10:13 from (4.244.57.143):
In Reply to: Farmall H 12 volt conversion posted by Shahn on June 24, 2008 at 06:49:53:
As the others have said but because of having a mag you do have one problem that is easy to fix. You either need to add a switch to your system so as to turn on the alternator or it will run your battery down. The last one I did that had a mag I put in an oil pressure switch so as soon as the engine started it would switch the excite on the alternator on and when you shut the engine off it would then turn it off. Very simple to set up and cost about $10
