double bevels on an m
Posted by jaker on June 24, 2008 at 08:25:57 from (74.47.224.154):
I want to put a set of 15.5x38 tires on an m that are mounted on a set of double bevels. Can I just use the blocks and bolts from the 400 on the m. Or do I have to change the cast center. I would rather not changed the center.
