Re: FFA Project/Super M Wiring problem
Posted by Bob M on June 24, 2008 at 13:20:51 from (151.190.254.108):
In Reply to: FFA Project/Super M Wiring problem posted by Bryan Lively on June 24, 2008 at 11:47:18:
Bryan - Congrat's to your students (and yourself!) on completing the restoration!
If you used a Delco 10SI alternator for the 12 volt conversion John T hit it on the head: You need a warning light, resistor or diode in the circuit between the ign switch and the alternator #1. Without it the alternator will "backfeed" sufficient current to the coil after the switch is opened to cause it to fire and thus the engine to continue to run with the switch "off".
Punch below for a diagram.
