Re: ?? Farmall 560 Diesel
Posted by Brownie 450 on June 24, 2008 at 18:54:57 from (216.51.158.151):
In Reply to: ?? Farmall 560 Diesel posted by Harold Hubbard on June 24, 2008 at 06:07:17:
Once warm, we never had any problems re-starting ours without using glo-plugs. You need good batteries, & the compression should be good-however. Even at $4 a gallon, that 560 uses so little fuel at idle that it won't cause a financial burden. Cool the tractor down for at least 2 minutes after working it hard so the heat dissipates.
