584 hydraulics sometimes quit
Posted by D.G. Young on June 25, 2008 at 03:47:11 from (72.236.237.35):
My 584 3 pt hitch and remotes may quit working while mowing or plowing, etc. and then return after several minutes even though I continue to use the tractor. The steering and brakes are not affected at all. This has happened before and I cut the tractor off and came back in about 30 minutes and all was fine. Yesterday it quit lifting while using a disc mower and neither the lift or remotes worked but I was able to continue mowing. About 10 minutes later the lift came up(I had moved the handle and left it at top of quadrant) and all was fine while I mowed for an additional hour. Can anyone tell me what the problem is? A local shop says I need a new pump which he will be happy to install but I can't see that being the problem. I wonder about a sticky valve and have thought about trying some automatic transmission shift conditioner or similar fluid. The filter and fluid have been changed recently.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
