Re: Farmall M has intermittent miss
Posted by RustyFarmall on June 25, 2008 at 07:29:48 from (209.152.78.71):
In Reply to: Farmall M has intermittent miss posted by chadd on June 25, 2008 at 06:22:33:
It's not so much that the compression is low as it is that the compression readings are very uneven. Your best bet is to remove the head and take it to a reputable machine shop. They can tell you if the head is cracked, might be able to repair it, and can give it a valve job. You will be amazed at how much better that ol' M runs.
