In neutral, when the differential drive gear is NOT turning, (and thus the shaft with the pinion gears is not revolving), then yes, the wheels will turn in the opposite direction.
When in gear, and the diff drive gear is turning and taking the pinion-shaft-and-gears with it, then the wheels will turn in the same direction.
However, in that last instance, when the wheels aren't 'bound' to the ground by their weight, and can 'free-wheel', I believe that though they are both going in the same direction, the potential exists for them to be slightly out of synch to each other (due to what? Maybe some variable resistance to one wheel due to difference in bearing tightness, or weight of tire, or one brake dragging, stuff like that), but yes, their tendency will be to rotate together in the same direction.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
