Posted by rumplestiltskin on June 25, 2008 at 10:21:15 from (192.88.212.44):
In Reply to: IH eagle posted by jpsepp on June 25, 2008 at 06:51:49:
I've never encountered what you're describing, but if I understand you correctly you should be able to make your own driver from a Torx screw. Just find one with the right size head, tightly lock the threaded end in a pair of Vise Grips, and use the assembly as you would a nut driver.
On the other hand, you may be describing a tamper-resistant Torx screw. These have the normal recessed Torx socket but also a small rod in the center of the hole. The rod prevents the insertion of a regular Torx driver. If this is what you're facing, you can buy special bits from tool or electronics suppliers.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
