Re: 12 volt back to 6 volt of '51 M
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Ludwig on March 15, 2000 at 05:38:18 from (208.201.105.165):
In Reply to: 12 volt back to 6 volt of '51 M posted by John on March 14, 2000 at 12:09:37:
I didn't see where anybody mentioned it, but you'll want to check out what the igniton system is up to.
If you've got a magneto system leave it alone, its fine, if its a coil system you should find that there is either a resistor somewhere to step down the voltage to the coil, or that the coil has been swapped all together.
A 12v coil on 6v, I dunno for sure, but I would guess it isn't worth a darn.
Post A Followup
: Re: Re: 12 volt back to 6 volt of '51 M
