GeneMO said: (quoted from post at 12:44:50 06/25/08) Crawl under the tractor. Look right underneath the very rear of the rear end casting, under the PTO. There should be a drawbar bracket for lack of a better word. Then look mid way under the big rear end housing about in the area of where the step is. There should be holes there for another bracket, if not the actual bracket. .......
Gene
Early model 706 did not have provision for the other drawbar on the rear sway control castings. You may have to replace them too if you are going to add the other drawbar.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
