Re: Hy-Trans or 80/90?
Posted by The tractor vet on June 26, 2008 at 11:10:28 from (76.212.228.133):
In Reply to: Hy-Trans or 80/90? posted by wallacedw on June 26, 2008 at 10:58:02:
If your 400 has a T/A then the only thing to use is Hy Tran . Yes when they were new they came with 80-0 but they found out that using 80-90 they would slip the T/A when cold so they came out with Hy Tran . One oil for the trams. Diff. and hyd. Now to keep the oil as clean as one can in one of th3e older tractors is to try to keep it out of the rain as rain water will run down the gears shift and get into the rearend and trans. What i like to do is crack the drain plugs in the spring before using the tractor after setting all winter and drain off any water that built up from condensation before and this helps .
