Re: question on 1466
Posted by the tractor vet on June 26, 2008 at 11:20:52 from (76.212.228.133):
In Reply to: question on 1466 posted by ihjerm1206 on June 26, 2008 at 11:11:24:
Well here goes the could BEEEeeee's Could be low cranking pressure on the injection pump , could be low cracking pressure on the part of the injectors, could be low compression on part of the engine due to being wore out , could be broken top rings on the pistons , could be the valves are out of adjustment or have sunk to far into the head maken for low compression. With out me personaly looking at the tractor and doing some checking we are just guessing.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
