Re: SC hydraulic pump
Posted by CNKS on June 26, 2008 at 17:37:33 from (216.144.104.128):
In Reply to: SC hydraulic pump posted by Idaho Ron on June 26, 2008 at 16:08:23:
The parts manual has pump numbers and the pump itself has corresponding numbers stamped on it -- they are in the parts manual or www.caseih.com. I believe yours has an o-ring, which is generic and available at NAPA, or better, a bearing/seal business. CaseIH likely has it in stock. If the shaft itself has a deep enough groove in it, you will need a speedi- or redi-sleeve. This requires enlarging the hole the pump shaft goes through. Best to have that done at a machine shop, which can also supply the seal and sleeve. It is a simple repair.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
