Re: Super A stutters dies under load
Posted by CNKS on June 26, 2008 at 17:43:18 from (216.144.104.128):
In Reply to: Super A stutters dies under load posted by Rad Red on June 26, 2008 at 15:29:14:
Your carb is not adjustable, except for the float and idle. Main mixture is a fixed jet. Disassemble, soak in carb cleaner overnight, blow out with compressed air, and put a kit in. Could be ignition, but it sounds like the carb. Disassembly is self explanatory -- or refer to the parts section on www.caseih.com. The kit may include a diagram.
