DH - Ideally the fuel solenoid should be fed direct from the "I" (or "IGN") terminal on the ignition switch.
Alternate locations:
If your tractor does not have an ignition ballast resistor the solenoid can be fed from the ignition switch side of the coil primary (do not feed from the coil primary side connected to the distributor!)
Or if the tractor DOES have a ballast resistor connect it to the ignition switch side of the ballast resistor.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
