Re: 1948 Farmall Super A implements
Posted by Hugh MacKay on June 26, 2008 at 17:56:07 from (216.208.58.114):
In Reply to: 1948 Farmall Super A implements posted by Kevin Pitts on June 26, 2008 at 16:29:26:
Kevin: Back when Super A was new there were a wide variety of ground working tools for you cultivator. There were several plows, sickle mowers, a blade that coud be mounted front or center mount.
Three point hitches will work, but you must get the mechanical advantage right. These little tractors don't have big hydraulic power. It can be done in such a way the hitch will lift implements weighing up to 600 lbs., provided that weight is not more than 3' back from hitch point. They fall down fast on implements that extend back more than that.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
