Posted by Hugh MacKay on June 27, 2008 at 08:33:38 from (209.226.247.100):
In Reply to: Super A Plow posted by mark on June 26, 2008 at 18:10:22:
Mark: mkirsch is right, all plows on Super A have plow depth controlled by hydraulics. Left valve lever and inside left rockshaft lift and lower plow, right valve lever and right rockshaft controll plow depth. With drawbar in forward position, you remove pins to allow it to float. then run a link from drawbar to right rockshaft. It has to pivot top and bottom and top end muct be offset so it wont break rockshaft arm ends.
Once you get that your in business, you'll have hydraulic depth control change on the go.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
