Farmall/IH couplings MTA/300/350/400/450
Posted by dkennelly on June 27, 2008 at 09:30:33 from (162.123.17.83):
I originally posted this in the General Tractor forum and got no hits. I'm sure the Red folks should have some information:
I just traded my H for a '55 300. Got home and went to hook it up to the disk, found out that I had not paid attention to the hydraulics on the 300. Not that it would have made any difference..
All 6 fittings are original. I'm trying to get ahold of the rear quick disconnect bracket and fittings, but the question is, how do the 4 front fittings work without the quick disconnect bracket to hold the fittings on? Can I still get these fittings? The tractor-side fittings have flat faces with threads around where the pullback sleeve would be for a Pioneer fitting. I'm sure that I can just change them out for Pioneers, but would like to use the old fittings and make short hose adapters instead.
