Re: Checking Super A Oil Level (???)
Posted by Hugh MacKay on June 27, 2008 at 17:58:23 from (209.226.106.115):
In Reply to: Checking Super A Oil Level (???) posted by Rad Red on June 27, 2008 at 16:23:15:
Red: Those petcocks are a more accurate system than a dipstick. Keep the oil level between them and it will operate just fine. If oil is coming out the upper petcock, put a can under it and let drain down to that level. Just about everyone that ever popped a crank seal did it by having the crankcase over full. Most wont admit it, but that is the cold hard fact.
Take Mike's suggestion and get your self an IH operator's manual. There are items in the maintainence section that will cause you a lot of grief if not serviced. Two things that come to mind are lubrication of fan hub and distributor drive. Who wants a fan through the radiator at $500. and who wants to burn up the distributor drive gears at $175. per set?
