The 706 has a resistor wire between the ignition switch and the I terminal on the solenoid. That wire serves as the ignition resistor. When the solenoid is engaged the I terminal is also connected to battery voltage internally to supply cranking voltage to the coil for a better spark while cranking.
The I terminal at the solenoid should have two wires connected to it. They are probably joined together in the terminal that connects to the solenoid. The S terminal has only one wire going to it. The S terminal needs battery voltage applied to it to engage the solenoid. The I terminal is energized by the solenoid while the starter is engaged to supply 12 volts to the coil while cranking. With the engine running you should have about 6 volts at the I terminal since power is supplied by the ignition switch but it is coming down the high resistance wire which serves as the ignition resistor.
If you were to connect the fuel cut off solenoid to the I terminal at the starter you would not be getting 12 volts once the starter disengaged and most likely the engine would not stay running. The power needs to come from up at the ignition switch and not the starter.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
