Voltage regulator adjustment
Posted by HENRY E NC on June 28, 2008 at 12:07:14 from (216.119.6.202):
After many posts, much anguish and three trips to the people who fix generators, many trys at adjusting the VR with a needle nose pliers I have finally gotten my A to charge. It is now charging 7.2 V and as high as 12 amps at high throttle( Battery Low). Now here is the kicker!!!!!!!!!!!there is and adjustment screw on the Tisco VR to adjust the normally closed points. No bending is required. The screw loosens the platform to relieve tension on the point. oNLY TOOK A YEAR TO FIND IT. Saved me much headaches. NUff said Henry
