Re: 560 stalling problem
Posted by the tractor vet on June 28, 2008 at 17:44:00 from (76.212.237.159):
In Reply to: 560 stalling problem posted by Gary Schoborg on June 28, 2008 at 16:39:51:
Check your flow of gas to the carb . check and make sure that the main fuel adjusting screw is 4-5 turns off the seat check ing timing at full throttle and it should be 24-26 degrees BTDC . Also use at least 89 octain on that engine .would run better on 93 .
