Posted by Roger46 on June 29, 2008 at 17:17:57 from (69.58.159.57):
In Reply to: Re: 450 cluch posted by 1958ih450 on June 29, 2008 at 16:16:42:
If the bigger of the two input shafts to the transmission does not turn it is a problem with the PTO as that shaft drives the independent PTO directly from the engine bypassing the clutch. Check the band adjustment in the PTO unit in the back to make sure they are adjusted correct. If that is OK you may have to pull that unit or it could be a problem with the drive system in between (which is probably unlikely). Roger
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
