Re: IHC 430 International Baler with Thrower Problems
Posted by JimB2 on June 29, 2008 at 19:01:15 from (99.241.179.24):
In Reply to: IHC 430 International Baler with Thrower Problems posted by Robert Shifflet on June 29, 2008 at 15:54:48:
Hi Robert it is the spring that becomes weak on that aluminum pulley. We drilled two bolt holes in the pulley and put shims on bolts in between pulley halves and tightened the bolts. Now pulley is fixed and control the distance to throw the bales by RPM of the tractor. Are the throwing rollers grabbing the bale properly? All belts have to adjusted properly and not slipping to throw properly.
JimB
