Re: Towing a Farmall M
Posted by JT on June 30, 2008 at 11:16:31 from (70.226.224.62):
In Reply to: Towing a Farmall M posted by J Norris on June 30, 2008 at 07:26:11:
Call me a chicken, but I, under no circumstances, would put an M behind anything less than a 3/4 ton "rated" truck. You may have the abilty to pull 8000 punds, but you do not have enough truck weight to control the trailer, not enough rubber on the ground, when you go aorund a curve, you have a lot of weight on the trailer trying to push you side ways. I would hire it to be moved, there are a lot of people out there that will haul for $2.00-$3.00 a loaded mile, and that is cheap if you destroy a truck and tractor because not being loaded correctly.
My Dixie chopper mower has a tow rating on 2000 pounds, so as you can see, tow rating is not a lot of assurance for towing.
Jim
