Re: Farmall problem with oil
Posted by Andrew Z on June 30, 2008 at 12:54:22 from (76.243.121.6):
In Reply to: Farmall problem with oil posted by JonathanSuperC on June 30, 2008 at 12:44:27:
There is seal that is on the pump shaft that is leaking into the crank case. You have to remove the pump and take apart the pump and change the seal out. If the pump shaft has a ridge or groves in it then you may need to put a speedi sleeve on it to get a good sealing surface. Over all its a pretty easy fix, just time consuming removing the hydro lines and pump in all. I would sugest a manual that way you know how to work on the pump.
Andrew
