Re: How big a disc can an H pull?
Posted by dkennelly on June 30, 2008 at 14:00:17 from (162.123.17.81):
In Reply to: How big a disc can an H pull? posted by ghouse on May 27, 2008 at 10:57:19:
I have a '49 H and it is a very good runner, nice and tight in all respects. I pull an old hydraulic lift JD 8' tandem disk which is far heavier that my neighbor's 8' disk. I can pull the JD in 4th at full throttle until I hit sand, soft or wet areas and have to drop it down to 3rd. The 8' cuts well and I wouldn't think of using another disk with it. My '55 300 can take the same disk and really move through the field with it no sweat. The difference in 10hp. You might be able to pull a 10', but it'll be a light one and you have to ask yourself if you're doing any good in the field because you'll be in 3rd. Wait and find a good 8' disk, they're still around and you can get it through the gates.
