Re: Cub front axle
Posted by Haas on June 30, 2008 at 17:50:09 from (12.65.54.51):
In Reply to: Cub front axle posted by razimm on June 30, 2008 at 06:22:28:
My experience with a Cub front axle... Tried penetrant, heat, portapower, rigged uppuller with all thread. Never did get it out. Took it to shop that does my welding. They could not get it to break loose either. Ended up splitting the back side of the outer tube with a grinder, then spreading it enough to get it loose, then rewelding the split. My welding shop did this and is not noticeable at all after grinding smooth and repainting.
