Re: Re: Re: More oil on the outside than the inside,Super C
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by SteveF on March 15, 2000 at 18:18:50 from (208.170.187.191):
In Reply to: Re: Re: More oil on the outside than the inside,Super C posted by Paul Shuler on March 15, 2000 at 13:17:35:
Yes these 6 bolts will separate the bellhousing from the engine. There are several small pieces that need disconected first. Throttle linkage, fuel lines, electrical, steering shaft, etc. Rent a large engine hoist. Pick up the tractor with the hoist, support the bell housing with a couple cement blocks. Make sure the rear wheels are blocked. Ease the pressure off on the lift so it just supports the engine and bolster. Now loosen up those 6 bolts and separate the tractor about a 1/4". Drop of the lower bell housing guard. Before you go any further make sure the bolster and engine are properly balanced so nothing swings or twists suddenly when its totally unbolted. If you have to tighten up the bolts and reposition the chains. Have a friend on hand for this part to help steady and gently pull it apart. Working on these tractors can be enjoyable as long as your very careful.
Good Luck
SteveF
Post A Followup
: Re: Re: Re: Re: More oil on the outside than the inside,Super C
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
