Re: Farmall 450 conversion - diesel to gas
Posted by D Slater on June 30, 2008 at 18:42:48 from (72.65.142.9):
In Reply to: Farmall 450 conversion - diesel to gas posted by Andrew Kappers on June 30, 2008 at 16:34:50:
Easy to do if you have a complete gas engine. Hood sides are different but can be used, Gas air cleaner, hydraulic pump,lines, coolant pipe,and throttle notches needed. Also gas linkage rod from governor to throttle linkage lever near bottom of air cleaner. Also the lever has a little bigger hole than gas ones in it. Hand starting ratchet in bolster is different, if it matters.
Fuel tank can be used by pluging one outlet hole. If you change to a big tank the hydraulic lines under tank need changed also.
