Re: Charlynn Power Steering unit
Posted by glennster on July 01, 2008 at 05:31:04 from (75.56.50.121):
In Reply to: Charlynn Power Steering unit posted by Redstate on June 30, 2008 at 17:59:00:
the char lynn torque generator has centering springs in it so at the neutral or "center steer position, the hydraulic pressure is at its minimum. be sure the front wheels are in the straight forward position and the generator is located in its center position when assembled, otherwise the pump is trying to center the generator. also be sure there is no binding in the steering shaft from the steering wheel to the generator, it must turn freely. also be sure the lower steering shaft lines up with the output end of the torque generator. the coupling should slide in freely with no binding. the center position can be checked with a pressure gauge, 0-2000 psi, use a 3/8 pipe tee to install it in the line at the torque generator. watch the gauge when you operate the steering wheel, when the gauge reaches its lowest pressure reading, it is at center steer.
