Re: Super M hydraulic/transmission question
Posted by Bob M on July 01, 2008 at 08:52:39 from (151.190.254.108):
In Reply to: Super M hydraulic/transmission question posted by Jaybird2 on July 01, 2008 at 08:01:24:
J - Is it hydaulic oil or tranny lube that's leaking out from the inspection cover?
My guess it's leaking tranny oil out of the transmission front seal - or both front seals if your SM has a belly pump.
Fortunately the seals are inexpensive. And they can be replaced from underneath without splitting the tractor.
The transmission holds a LOT of oil (13+ gallons). Once the lube level falls below the countershaft gears the rate of leakage should slow way down. The bull gears running in the large "sump" at the rear of transmission should still throw up enough oil to keep it adequately lubed for a 2 mile ride home.
