Re: Super M hydraulic/transmission question
Posted by BOBM25 on July 01, 2008 at 09:05:37 from (74.218.59.34):
In Reply to: Super M hydraulic/transmission question posted by Jaybird2 on July 01, 2008 at 08:01:24:
These older farmalls don't use hytran like the newer ones do. The trans and differential use a gear lube like 80-90w. The belly pump is separate hydraulic oil. Bob is right. The trans/differential holds a lot of oil. A small leak wouldn't hurt much there. The belly pump wouldn't have to lose much to make your hydraulics inoperable. So the leak may be your front transmission seal if your disk still goes up and down ok.
