Posted by JimB2 on July 01, 2008 at 12:16:34 from (99.241.179.24):
In Reply to: 430 Baler problems posted by Joe Reusch on July 01, 2008 at 09:14:10:
Hi Joe, 430 balers had two different styles of knotters, regular and all twine knotters. The all twine knotters were a great improvement over the regular knotters. If it has all twine knotters it will be indicated on the decals. The common problem with the regular knotters were they were intolerant of inconsistencies in the twine (did not like thick & thin spots), always required a sharp twine knife and twine hold disk had to be adjusted to thickness of twine by adding or removing shims.
The Operators Manual has a good section on trouble shooting knotter problems. You have to look at the twine that is on the side that didn't tie. Is it long enough to go around the bale? Is it broken or cut from a worn part or nicked part in twine path? Is the bow tied or was it tied and has been pulled loose? Check cut ends of twine, clean cut or ragged with threads hanging out? This is indication of dull twine knife or miss adjusted twine knife. Compare good side vs missing side.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
