Re: IH loader from a IH350 will fit IH544?
Posted by mkirsch on July 01, 2008 at 12:20:07 from (64.80.108.52):
In Reply to: IH loader from a IH350 will fit IH544? posted by Bob Rose on July 01, 2008 at 08:59:37:
If you are expecting a bolt-on fit, the answer is MAYBE.
If you are willing to torch and weld, the answer is YES.
Which "IHC 350" and which "IHC 544" are we talking about? IHC made two versions of each tractor.
If both tractors are Farmall versions, then the loader should bolt right on.
If either, or both, tractors are Utility/International versions, then you will probably have to do some cutting and welding.
Do you know the make and model of the loader?
