Re: IH 330 not charging
Posted by Bringselpup on July 01, 2008 at 19:48:49 from (66.243.209.35):
In Reply to: IH 330 not charging posted by Andy Motteberg on July 01, 2008 at 18:58:14:
Thanks Bob, my ammeter up in the panel does look pretty nasty.
Can I bypass the ammeter for now just to see if I can make 'er charge again?
Bob M said: (quoted from post at 22:18:49 07/01/08) Your assumption is correct: You should see battery voltage at the regulator BAT terminal at all times. I'd be looking for a break in the wiring between the ammeter and the regulator, or (long shot possibility...) an open-circuited ammeter.
