Posted by Paul in MN on July 02, 2008 at 17:24:11 from (71.210.156.101):
In Reply to: overheating super h posted by steve in sw mo on June 30, 2008 at 15:39:03:
Steve,
I had an overheating problem with the H, and I knew the radiator was clean. I found the water baffle plate on the left side of the engine block was seriously corroded internally. This plate has a formed sheet metal passageway to direct the water from the water pump to the back 2 cylinders of the block. When rust destroys the water channel, the back cylinders overheat. Once I took the plate off, I was amazed at the amount of rust and crap that was built up around the cylinder jugs. I took the pressure washer to the mess, put a new baffle plate on and have no problem since. The plate was available from CNH and OEM, and maybe from this site.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
