Re: diesel problem ????? need HELP
Posted by JimB2 on July 02, 2008 at 17:45:19 from (99.241.179.24):
In Reply to: diesel problem ????? need HELP posted by johninpennsylvania on July 02, 2008 at 06:27:28:
Hi John, yes there is a front drive shaft seal on those injection pumps. See pictures of the DPA
injection pump at this site:http://www.realdiesel.com/dpapump.html
The instructions to remove/re-install this pump were in the archives under B414,434,444 or BD154.
If you do decide to remove it yourself, be sure to put scribe marks on the pump and the mounting plate so you re-install the pump in the exact location you removed it from. Timing is adjusted by rotating the pump in the slotted mounting holes and any slight variation in either direction will mess up the timing. If I recall there is a key or pin that goes into the timing gear but on re-install pump can be 180 degrees out of time if the pump shaft has been rotated, so solution is to remove pump and turn shaft in direction of arrow 1 rev and re-install.
I agree with the Vet for this DPA pump take it to a shop as the front drive hub has to come off to replace the seal. On a Bosch pump the seal can be replaced without disassembling the pump.
JimB
Today's Featured Article - On the Road with Dave Gohl: Tractors and Farming - by Dave Gohl. I never thought I'd live to see the day, when I could call myself a farmer. What allows me to say this? Well, when our family moved to our 20 acre site near New Prague, Minnesota, I had one thought in mind. You guessed it, farm it somehow. A little history is in order. In my younger days, mom, dad and my brother made frequent visits to dad's youngest brother Pete, who took over the home farm from grandpa MIke. It was the typical set-up, milk cows, pigs & chickens. In the winter, we'd play ... [Read Article]
