Re: Towing a Farmall M
Posted by charles todd on July 02, 2008 at 21:03:08 from (205.242.95.139):
In Reply to: Towing a Farmall M posted by J Norris on June 30, 2008 at 07:26:11:
I run 45-70 with trailer brakes (both axles) and do not use OD and the tow/haul is on (Chevrolets use this, increases the trans psi). I load it with enough tounge weight to be propotional with the gross trailer weight (approx 20% - 40% total). I know a 1/2 ton is about 500 lbs lighter than a 3/4 ton and has less brakes (Chevrolet 4 wheel disc SUCK!). Use good judgement.
