Re: Cub stops running
Posted by james rumph on July 03, 2008 at 03:04:46 from (67.149.185.0):
In Reply to: Cub stops running posted by John Halford on July 03, 2008 at 02:19:31:
Very simple test >
Use a volt meter and check voltage going into coil 12v.
Now check voltage coming out of coil or balaest resister 6 - 8 volts .
Auto coils can be used "but" a external balast resister "must" be used.
The wire that would go from the coil to the dist is the wire you put the balast resister in .
Also check compression when hot and cold to see if there is a bad head gasket etc etc etc ...
