Posted by Dellbertt on July 03, 2008 at 04:08:22 from (209.172.21.118):
In Reply to: Cub stops running posted by John Halford on July 03, 2008 at 02:19:31:
Not familiar with tractor. If it has a mag, have it rebuilt. Is the whole engine hotter than should be. Might be intake leak causing heat. Its obvious something is causing heat. Is carb set too lean. No crud in gas tank. If its electrical, go slow and make sure you have the correct components for your system and that they are wired right.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
