Re: How to tell when my 400 is not running?
Posted by El Toro on July 03, 2008 at 07:50:56 from (64.12.116.73):
In Reply to: Re: How to tell when my 400 is not running? posted by Kelly C on July 03, 2008 at 05:40:32:
When you need to use the choke is an indication the engine is starving for fuel. Pull the gas line at the carb and see if there's full stream of gas flowing. Use a clean container to catch the gas, too expensive to let it run on the ground. If there's good flow here, check behind
that tube fitting where your gas line connects for a screen. Could be plugged with crud. If it lacks power under load and that tractor has the main jet adjustment screw at the bottom of the carb. needs to be opened. Carb may need cleaning too. Hal
