Re: more power for the model H
Posted by Red Mist on July 03, 2008 at 18:11:53 from (67.142.130.20):
In Reply to: more power for the model H posted by bgarrett on July 03, 2008 at 09:05:13:
bgarrett said: (quoted from post at 09:05:13 07/03/08) I cleaned out the carburetor and got new spark plugs and my H is running smooth and steady but it should have more power. Other than setting the valve clearance, what can I check?
Is it possible to set the timing?
Are you sure it should have more power? Compared to what? H's are only about 24 hp.
Well.... you can start changing sleeves and pistons, put in a 300 or 350 cam, maybe an M&W power govenor would make it feel more responsive??? Is it an "X1" H (serial tag), or a multi-fuel? If it is a multi-fuel, you can change heads to an X-1 head and boost compression, which in turn, will boost power....
Not trying to be a wise-guy, but maybe you really want a Super H or an M? Hope this gives you some helpful ideas. mike
