That is as easy of fix that you will ever do , First remove the steering wheel with a steering wheel puller and two 1/4 inch fine thread bolts that are at least 4 1/2 inchs long as it makes it easier with the long bolts . Clean out the holes in the wheel and chase with a 1/4 fine tap . Remove the nut that holds the wheel on install the puller and tighten it up and give it a rap with a hammer and it will pop off . Next remove the snap ring that holds the seal in then set the steering wheel back on the shaft and give a quick hard turn don't care what way you turn it and the seal will pop wright out clean up and install new seal replace snapring and put the steering wheel back on and go to work .
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
