Posted by ScottyHOMEy on July 03, 2008 at 18:53:12 from (71.241.193.213):
In Reply to: Re: Hey, Rad Redrunner posted by Rad Redrunner on July 03, 2008 at 18:31:53:
Well, that ain't the best news I've had all day. 8<(
Just for giggles, why don't you check your valve stem clearances, and then check your compression, dry first and then wet. Something on the order of 80-90 psi wold be good, but something resembling uniformity across them is more important.
It could be you need a ring job, and that would mean splittin' the tractor, but it could be a bad head gasket, which makes a plesant afternoon's job. Better yet, do it in the morning and drive your tractor in the afternoon.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
