If your coupler on the bushhog is a "C" type and I am sure it is, don"t make it fit tight on the drawbar. It needs room for clearance on uneven ground. If you have it tight right now, just leave it be and it will bend itself to the right amount when using it. When adjusting the drawbar remember if the rear tires spin, raise the bar. If the front tires lift lower the bar. The swinging drawbar is acually mounted in a place to minimise the chace of it flipping over backwards since it pulls from in front of the rear wheels, but may cause problems with PTO shaft if left "swinging".
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
