Re: How do I take off a Westendorf WL21 loader
Posted by leroy in ne on July 04, 2008 at 13:45:57 from (67.63.106.62):
In Reply to: How do I take off a Westendorf WL21 loader posted by Mike Norton on July 04, 2008 at 12:49:32:
don't know or sure on 21 loader but the 26 i use bucket must be flat on ground, unlatch as indicated back out some (you may have to slightly raise or lower to get loader to slide back) use lift cylinders to lower front of loader frame to ground until it is about verticle, this is the support stand, shut tractor off and work hyd. valves to remove pressure. disconect hoses and back away from loader. reinstall by reversing procedure. i do this frequently as i use tractor with other equipment that is a pain with the loader on while working in close quarters
