Run a hose from the drain plug on the belly reservoir to the intake on the pump. Run a second hose from the output of the pump to the input on the valve (I think that's the topmost hole). Connect the bottom of the IH valve to the fill port on the reservoir.
Replace the vented cap with a sealed cap or oil will spray out regardless of whether you have it connected properly or not.
Run two hoses from the work ports on the valve to quick connects on the rear of the tractor.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
